Ha, me too! That plumbing, unfortunately, is a joke. Especially with the red race valve. We'll see how I did when I get to the WOT pulls of my tune.1.5 to 2K that is part of the reason I went with the Procharger. Installs are not cheap I may have to take it to a local shop to re-do my intercooler piping. Busted my knuckles pretty good over the weekend I can't grip a tool right now with that hand.
Only thing that really bothers me about the kit is you have to cut the tubing to make it fit. It should come cut to the correct sizes already. I am adding the red race valve but letting a shop do that part.Ha, me too! That plumbing, unfortunately, is a joke. Especially with the red race valve. We'll see how I did when I get to the WOT pulls of my tune.
Which one you all having trouble with? The head unit to the IC? That was the one I thought was most difficult. Windex is your friend!!Only thing that really bothers me about the kit is you have to cut the tubing to make it fit. It should come cut to the correct sizes already. I am adding the red race valve but letting a shop do that part.
Cutting the one that goes to the exhaust port of the head unit. Then fitting the elbow from the exhaust tube that you cut into the piece going to the inter cooler. Just feel they should be the proper length without cutting it.Which one you all having trouble with? The head unit to the IC? That was the one I thought was most difficult. Windex is your friend!!
Yep. That's exactly it. The outlet elbow from the head unit and the inlet trying to squeeze in between the red valve. The cold side piping was pretty much perfect out of the box. I'm definitely going to try and find a shop that can do something about the placement of the red valve as I'm not happy with how tight the fit is at the moment.Cutting the one that goes to the exhaust port of the head unit. Then fitting the elbow from the exhaust tube that you cut into the piece going to the inter cooler. Just feel they should be the proper length without cutting it.
The intake of the head unit was not easy but just used a lot of silicone spray and it went on after about 15 minutes of fighting it.
Just wanted a Avg cost for a super charger, install and tune.
