Any lowered cars running 295/35/19 square setup?
6G
California
2016 Mustang GT Premium
Are there any lowered cars running 295/35/19 square setup? If so, did you need spacers up front? does it rub in the front? Or any other issues? I have the Ford track handling pack (M-FR3A-M8).
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Ive done it before it all depends on the spec of the wheel.
  • Like
Reactions: 6G
6G
6G
California
I run 295/30/19 squared on MMD 19x10 wheels with 25mm adapters. I don't know the clearances of the FTHP, but I was rubbing with spacers.
Thanks tor the reply! So I should be okay with a 25mm spacer.
I would most likely be running a 19x10 wheel. Would that be okay?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Yes sir I have done a 19x10 with 305 tires upfront, it all depends on the spec you want to use, but as you can see it has been done.
  • Like
Reactions: 6G
6G
6G
California
Got it! Thanks for your help brother!
GT Jeff
KS
2016 GT/CS
Bringing the thread back from the dead....
Any idea if you can run them easily on the M350 19x10s with a 1-1.2" drop?
