ahl395's Build Log - Methanol Injected / P1X / 4500W sound system
ahl395
ahl395
Allan
If anyone is still following this....
Got tired of those damn breathers dripping EVERYWHERE and installed a new catch can.
Got a fabled Boostworks catch can from a friend. And even though they say it works with Prochargers, it just doesnt. I tried everything I could and the pulley just sat way too close for my liking (less than a half inch).
So I set out to make it useable as I think it's the best designed catch can I've ever seen. Large capacity, nice fit/look, and a sunk in breather so dripping is not possible.
Here you can see it's way too large to fit, so I brought it to a welding shop and had it cut down a few inches.
Painted it up and installed, I couldn't be happier with the outcome and look of it.
And for the bonus treat, I had a bung welded on the bottom and ran a drain line down to the bottom. Right next to the Procharger drain, I can simply empty the can at every oil change. SO much easier than breathers, or my old catch can.
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Welcome back 🙂
DFB5.0
Australia
Mustang GT Fastback
Always love seeing updates in this section, so yes still reading. :thumbsup:
Andrewg
Sun, Sea, Sand and Camels
Dubai, U.A.E.
Andy
2015 Guard Metallic GT 401A
Definitely still following. In the process of getting a new block put in mine after my cylinder 8 died too. Love that catch can! May well be an option for mine too.
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
how many miles on the original engine? Are you going with a direct stock replacement?
Andrewg
Dubai, U.A.E.
Andy
About 45k total miles. Tuned tight with a bad tank of gas on a long, hot pull. Learned a hard lesson. Engine technically still ran but smoked bad as the ring was toast. Going with a stock gen 3 short block and will re-use my gen 2 heads.
