evo8904
I'm a member???
So, my stock clutch was fine but I decided to swap it at the same time as my gears. I went with a ACT FM13-HDSS - HD/Perf Street Sprung since it is rated at 44% over stock. I have put around 200 miles on the clutch so far and it is holding with no problem. Today I decided to do a 3rd gear pull. I went to shift between 7000 and 7500 rpms. I pushed in the clutch and shifted to 4th, then let out on the clutch. When I let out on the clutch...it stayed on the floor??? It popped back up once the rpms decreased. I thought that it was in my head. I tried it again about 10 mins later and the same thing happened. Anyone have any ideas of what it could be? I removed the helper spring months ago and never had this issue with the stock clutch. Is this a situation where the rpm's create a centrifugal pull on the pressure plate fingers?
