2020 GT500 Front End Close Up Photos
Mountain376
SE Michigan
'17 Camaro SS 1LE, '16 Camaro SS, '12 Mustang GT
I haven’t seen photos like this posted so here you guys go:
FastCarFanBoy
2013 GB GT
Looks like you can see the yellow filter media through the air intake, and i assume those are brake ducts on either side of the lower grille. All good signs
protraxduner
OK
2020 Shelby GT500 Race Red
Any pics of the Cobra? Can it be removed permanently leaving just the honeycomb?
Mountain376
SE Michigan
Right and the red you can see a little is, from what I could tell, the brake calipers.
Mountain376
SE Michigan
No... I did not. I did not think of that! But if you look at the spy shots, they didn't have the Cobra emblems. It looks like you can, and make it look clean, but with a little work:
If you want the blowen-up pic:
https://st.motortrend.ca/uploads/si...rd-Mustang-GT500-mule-front-three-quarter.jpg
The black plastic backing/silhouette looks like it is part of some kind of inner-grille surround. The outer mesh grill looks separate. Might be able to remove the inner-grille and/or cut the Cobras black plastic backing off.
protraxduner
OK
Yeah on the spy photo i cant tell if that is just a painted black cobra or if it is backing and part of the grille surround.
dman
ventura, ca
2017 gt pp lightning
...not sure if those are brake ducts but, thought I saw a couple of chickens behind the "fence"? 2017 Super Snake...that's a grille. also, with a similar octagon design, check the Multi-matic GT4 track stangs...at least they don't look like "chicken wire". dman
