1/4 Mile Fast List 3.0
cahouston
Houston
2019 Mustang GT A10 Premium
Hello everyone, since the last person who was maintaining the fast list has moved on and that post used a fixed image, I will help take up the torch so to speak. We will use a shared Google sheet to track the list. Over time, if it becomes too much for one person, I can give edit rights to others and it should automatically update here.
This will be one big list, not broken down into engines, years, or mod categories. But the engine, year, and forced induction or not will have highlighted color sections for identification. Ranking will be based on 1/4 E.T., and tie breaker by mph. Engines will be highlighted by different colors so you can see where you stand.
RULES:
1. Post the details of your quarter-mile pass . You can post just a pick of your time slip showing all the slip with date and track name. List ALL of your related mods. IF YOU DON'T POST ALL OF YOUR MODS YOUR SLIP WILL BE IGNORED.
2. Please keep discussion to as minimal as possible.
Vehicle, Trim, DRAG MODE USE Y/N & Options:
Modifications (if any):
R/T.........................................
60'..........................................
330'........................................
660'........................................
660’ mph.................................
1000'......................................
1320'......................................
1320’ mph….............................
race weight w/driver:
Name of the track:
Date of pass:
Weather conditions: (include the Density Altitude if possible):
You can use this DA CALCULATOR
3. Upload an image of your time slip directly onto Mustang6G and not a third-party photo service (to ensure the images are never lost).
The full time slip must include the date/time of your pass and identify the track that issued the slip.
cahouston
Houston
Quick update, the above date was taken directly from the last list along with all updates posted in the Fast List 2.0 thread since the last update in July 2020. Please post updates here with the above guidelines and I will get the list updated. Let me know if you find any issues with the data as again, it was taken from the prior list along with updates in that thread.
Jed S.
Irwin, Pa
Jedidiah
2018 Whipple Stage 2 Mustang GT
CHEETO Mod List:
2018 Mustang GT Base, A10, Stage 2 Gen 5 Whipple, 6 rib, 132mm TB.
3.25” Griptec Pulley (16lb boost)
Texas Speed Long-tube Headers
Corsa Extreme Cat-back
Lund Racing E85 Tune
ID1050X Injectors
Fore Innovations LVL 2 Return Style Fuel System
BMR “Bread N Butter” Package
Eibach Pro Springs
Circle D Converter
Richardson Performance Built 10R80 Transmission
QA1 Carbonfiber Driveshaft
Driveshaft shop 2000hp Axles
RPM 6-point Rollcage
Hawk Performance HPS5.0 Brake Pads
DBA Slotted Rotors
Racestar “Poorstar” Drag Pack with MT Tires
Keystone Raceway Park
DA: 400
Raceweight: 4100
rabid_josh
Columbus, OH
Josh
2020 Ford Mustang GT
Vehicle, Trim, DRAG MODE USE Y/N & Options: 2020 GT 401A A10 PP1 Drag mode used
Modifications (if any): Roush xpipe, Flex tables loaded, running e85 pump. Mickey Drag Radials 305/45r17s
R/T........................................... .385
60'.......................................... 1.770
330'........................................ 5.021
660'........................................ 7.681
660’ mph................................. 92.64
1000'...................................... 9.970
1320'...................................... 11.903
1320’ mph…............................. 116.82
race weight w/driver: no idea never scaled, stock no weight reduction
Name of the track: National Trail Raceway
Date of pass: 10/8/20
Weather conditions: (include the Density Altitude if possible): 1620ft, 46% Humidity 67 degreees
69Mach
Sebastian FL
69 Mach 1, 2017 Mustang GT
Vehicle, Trim, DRAG MODE USE Y/N & Options: 2017 GT 401A A6
Modifications (if any): Hellion Street Sleeper, e85 pump. MT Street R 305/45r17s 11.5 lbs of boost
R/T........................................... .050
60'.......................................... 1.476
330'........................................ 4.069
660'........................................ 6.246
660’ mph................................. 111.91
1000'...................................... 8.122
1320'...................................... 9.691
1320’ mph…............................. 146.78
race weight w/driver: 3970
scaled
Name of the track: PBIR
Date of pass: 1/8/21
Weather conditions: (include the Density Altitude if possible): ~350
WhinRR
Ohio
Sean
1988 Ford Mustang GT, 2018 Ford Mustang GT
Tune only 20 PP1. Track mode used.
1.94
7.769 @ 94.12
11.921 @ 118.16
DA 800+
OSW 12/3/20
Jeez these auto’s put out crazy times with no mods!!
cahouston
Houston
Hey everyone, when I like your post, it means your time has been added to the sheet.
cahouston
Houston
Vehicle, Trim, DRAG MODE USE Y/N & Options: 2019 GT Premium A10, 3.55, Drag Mode.
Modifications (if any): Stock tune, front skinnies, MT ET Street bias ply, BMR CB010, CB762.
R/T: 0.031
60': 1.792
330': 4.848
660': 7.343
660’ mph: 98.87
1000': 9.496
1320': 11.323
1320’ mph: 122.97
race weight w/driver: 3775 Lbs
Name of the track: Houston Raceway Park
Date of pass: 1/15/2022
Weather conditions: (include the Density Altitude if possible): DA -578
Zinc03svt
usa
stang
R/T: 0.031
60': 1.792
330': 4.848
660': 7.343
660’ mph: 98.87
1000': 9.496
1320': 11.323
1320’ mph: 122.97
Amazing what weight pulled out, traction, and sea level w/ - DA does for these 18 plus a10’s. Nice run.
cahouston
Houston
Thank you. Yeah, I'm amazed how fast this car is in good air with just the basics.
GuardGT
is currently pooping
CA
2018 Crimson GT 10r80
Modifications (if any): 18 base a10 in D
R/T......................................... .855
60'.......................................... 1.617
330'........................................ 4.340
660'........................................ 6.501
660’ mph................................. 114.99
1000'...................................... 8.342
1320'...................................... 9.903
1320’ mph…............................. 144.29
race weight w/driver: unknown. Some weight reduction with 160lb driver
Name of the track: Sacramento raceway
Date of pass: 12/6/2020
Weather conditions: (include the Density Altitude if possible): da +93ft 62*
2018 a10 base 3.15 gear
Stock trans/converter/driveshaft/ gt350’driver axle
Paxton 2200sl no filter 3.625 griptec PBD tuned
Pump 91 w/16oz torco
Snow methanol 2.5 kit with single jet (cooling purposes only) 625ml/min jet
Stock fuel system with ti267 pump, id1000s
Stock manifolds, cat delete, x pipe, stock axle back
Stock front suspension
Bmr rear drag springs, lockouts, toe rods
Forgestar d5s with MT et street ss @18psi
Kirkey driver seat, all other seats removed
Everything else stock
CORNYOTE
Oklahoma
Alex
2019 GT
2019 GT whipple gen5 3.0 @ 18lbs, Circle D converter, 325/50 ET-R
R/T......................................... 4.032
60'.......................................... 1.415
330'........................................ 3.931
660'........................................ 5.946
660’ mph................................. 121.62
1000'...................................... 7.675
1320'...................................... 9.134
1320’ mph…............................. 154.37
race weight w/driver: 3840
Name of the track: Thunder Valley
Date of pass: 23Jan2021
Weather conditions: (include the Density Altitude if possible): 50 degrees 895DA
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
359 feet DA
100% stock on street 235/50/18 A/S tires 3.15 gear A6
Deep Blue
Houston, TEXAS
Leo
2020 Mustang GT - (A10) Magnetic Gray/ Mustang #7
2020 GT (A10) 3.15 gear.
Mods: Steeda open CAI, American Racing headers with high flow cats., Magna Flow cat back, Flex Fuel tune, Nitto 555R II 275/40/18 drag radials.
Race weight with 1/2 tank fuel 3,980 lbs.
Car# 1460
