Scott's Orange Mayhem
Specs, Mods, Photos
YEAR
2018
MAKE
Ford Mustang
MODEL/TRIM
GT Premium
COLOR
Orange Fury Metallic Tri-Coat
ENGINE
5.0 L Gen 3 Coyote
TRANSMISSION
A10 - 10 Speed Automatic
PACKAGES
GT Performance Pack 1, Premier Trim Package, Safe and Smart Package
FACTORY OPTIONS
Shaker Pro Audio System, All Weather Floor Mats
MODS - POWERTRAIN / DRIVETRAIN
• Anchor Room Custom Coyote VIN Engine Plate
• Battery Tender Quick Disconnect Fused Trickle Charge Cable
• Blowfish Racing Sound Tube Delete Kit
• Boomba Racing Black Anodized Billet Coolant and Brake Reservoir Caps
• Corsa Performance Carbon Fiber Closed Box Cold Air Intake
• Corsa Performance Dry Air Filter
• Custom Pony Orange Fury “Coyote Performance Pack” Strut Tower Caps
• ESS Tuning G3 X-Trim Supercharger Kit – Inventory Pending Install
• Fore Innovations Vacuum / Boost Manifold - Inventory Pending Install
• Ford Performance Hood Struts
• Injector Dynamics ID1050X Fuel Injectors – Inventory Pending Install
• JLT Performance Passenger Side Oil Separator
• Mishimoto Resonator Delete H-Pipe – Inventory Pending Install
• Modify My Stang Orange Fury and Shadow Black Painted Engine Cover
• Trufiber Carbon Fiber Radiator Cover
• Trufiber Carbon Fiber Fuse Box Cover
• Trufiber Carbon Fiber Coolant Tank Cover
• Trufiber Carbon Fiber Brake Reservoir Cover
• UPR Products Dual Valve Catch Can System for Centrifugal SC – Inventory Pending Install
• UPR Products 2 – Port Quick Connect EFI Fuel Line Adapter – Inventory Pending Install
• UPR Products Black Anodized Billet Windshield Washer Reservoir Cap
• UPR Products Polished Billet Aluminum Radiator Hold Down
• Vortech Superchargers MaxFlow Fuel Pump Booster – Inventory Pending Install
• Zspec Design Ultimate Dress-Up Fastener Kit
• BMR Suspensions Drive Shaft Safety Loop – Inventory Pending Install
MODS - SOFTWARE / TUNE / PROGRAMMER
• HP Tuners Remote Tuning Device – Wengerd Performance Tuning (RTD3)
MODS - WHEELS / TIRES / BRAKES
Front:
• ARP 3” Front Wheel Studs M14 x P1.5 RH
• Baer Performance Pack 15” 2-Piece Slotted and Drilled Rotors
• MRR Design Wheels M350 Front 19x10, Offset 40
• Nitto NT05 275/35/ZR19
Rear:
• Baer Performance Pack 13” 2 Piece Slotted and Drilled Rotors
• MRR Design Wheels M350 19x11, Offset 55
• Nitto NT05R 305/35/R19 Rear
• Ford Performance (ARP) 3” Wheel Studs M14x1.5 RH
Front and Rear:
• Ford Motor Company Running Horse Wheel Center Caps
• Ford Performance TPMS Kit
• Monster Open Ended Black Lug Nuts - M14 x P1.5
• Carbon Fiber Valve Stem Caps
• Maximum Motorsports ¼” Aluminum Wheel Spacers
Drag Pack:
• Front VMS Racing V-Star Wheels 18 X 5, 12 Offset
• Front Mickey Thompson Sportsman S/R Radial 28 X 6R18 Front Runners
• Rear VMS Racing V-Star Wheels 17 x 10, 54 Offset
• Rear Mickey Thompson ET Street R’s 305/45/17 Drag Radials
MODS - SUSPENSION / CHASSIS
• Air Lift Performance 3P Bluetooth/iPhone Air Ride Control System
• Air Lift Performance 30 Way Dampening Front Struts with Camber Plates
• Air Lift Performance Rear Air Springs/Bags
• Air Lift Performance Polished 4 Gallon Air Tank
• Air Lift Performance Inline Water Trap
• Ford Performance Rear Control Arm Toe Link to Knuckle Bearing - Inventory Pending Install
• Specialty Suspensions Seamless 3 Gallon Air Tank
• AVS Evolve Compressor Pedestal Mounts – Inventory Pending Install
• AVS Evolve 3P ECU Pedestal Mount – Inventory Pending Install
• VIAIR Dual 485C Gen II Black Air Compressors
• Viking Crusader Double Adjustable Rear Shocks
• BMR Suspensions Cradle Bushing Lockout Kit
• BMR Suspensions Adjustable Rear Toe Rods
• BMR Suspensions Rear Spherical Vertical Links
• BMR Suspensions Rear Upper Shock Mounts
• BMR Suspensions Rear Generation II Upper Shock Mounts - Inventory Pending Install
• BMR Suspensions Rear Shock Brace for Gen II Upper Shock Mounts - Inventory Pending Install
• BMR Suspensions Adjustable Camber Links
• BMR Suspensions Differential Hardware Upgrade Kit – Inventory Pending Install
• BMR Suspensions Lower Rear Control Arm Bearing Kit – Inventory Pending Install
• BMR Suspensions Jacking Rails
• Kelltrac Performance Innovations Subframe to Chassis Stud Kit – On Order
• Steeda Autosports Rear Subframe Alignment Kit
• Steeda Autosports S550 Mustang Bumpsteer Kit – Inventory Pending Install
MODS - EXTERIOR
• Air Design Air Curtains
• Anchor Room Front Side Marker Light Vinyl Trim
• Anderson Composites Carbon Fiber GT500 Style Spoiler
• Anderson Composites Carbon Fiber Gurney Flap
• Carbon Cartel Carbon Fiber Side Mirror Cover (Replacements)
• Diode Dynamics LED Smoked Rear Side Markers
• Diode Dynamics 510 Lumens Backup Light
• Diode Dynamics Tail Light Sequencers
• Ford Performance Gloss Black 5.0 Fender Emblems
• HCM Carbon Carbon Fiber 5.0 Fender Emblem Overlays
• Morimoto LED License Plate Light
• Morimoto XB LED Headlights
• ORV Auto Gloss Black Vinyl Roof Wrap
• Tokwin Carbon Fiber Rear License Plate Surround
• Trufiber Carbon Fiber Mirror Triangle Covers
• Trufiber Carbon Fiber Rocker Side Skirts
• Trufiber Carbon Fiber Front Lip/Spoiler
• Trufiber Carbon Fiber Front Splitter – Inventory Pending Install
• Trufiber Carbon Fiber Rear Diffuser
• Trufiber Carbon Fiber Hood Vents
• Trufiber Carbon Fiber Deck Lid Panel
• Trufiber Carbon Fiber Tail Light Bezels
• UPR Product Gloss Black Front Grille Running Pony
• Velossa Tech Design Big Mouth Ram Air Intake Snorkel and modified grille opening
• ZL1 Addons Front Tow Hook – Inventory Pending Install
• Zombie Sticker Shack Orange Dots for 5.0 Black Fender Emblems
MODS - INTERIOR
• American Car Craft Polished Stainless-Steel Dead Pedal Trim
• The Carbon Core Performance Pack Carbon Fiber Dash Overlay
• The Carbon Core Carbon Fiber Media Console Overlay
• Cruzin Graphix Carbon Fiber Like Door Striker Plate Covers
• Diode Dynamics Interior LED Conversion Kit Stage 2, 340 Lumens – Inventory Pending Install
• Dyna Performance Carbon Fiber Speaker Trim Overlay
• Dyna Performance Carbon Fiber Shifter Trim Overlay
• Dyna Performance Carbon Fiber Shifter Overlay
• Dyna Performance Carbon Fiber Headlight Switch Overlay
• Dyna Performance Carbon Fiber Door Pull Overlay
• Eximius Leather 5-Button US Key Fob Covers
• Scosche MagicMount iPhone Dash Mount
• Steeda “Pop” the Trunk Lid Kit
• Trufiber Carbon Fiber Coin Tray
• Trufiber Carbon Fiber Window Switch Relacements
• Vesul Door Pull Cell Phone Storage Boxes
MODS - IN-CAR ELECTRONICS
N/A Currently
HISTORY / COMMENTS
• Dealer demo delivered November 30th 2018 and went directly into Winter Storage/Build
• June 2019 Ontario Mustang Club / JRP Season Opener – Best S550 Mustang
• July 2019 Universal Cruisers / OMC - Pick of the Week Best Mustang
• August 2019 Diamond Auto Collision Annual Fundraiser Car & Bike Show 2019 – Best Domestic
• August 2019 Woodbridge Cruisers, Fountain Tire’s - Pick of the Week Best Mustang Under the Hood.
• August 2019 Woodbridge Cruisers, Lan Insurance - Pick of the Week Best Mustang
• September 2019 Expo Summer Show - Best Domestic
• August 2021 Highway 11 Cruisers & Ontario Mustang Club – Top 8 Best of Show Mustang
Comments
Item information
Added by
Scott
Views
1,965
Last update
More in Mustang GT
Share this item
