That looks greatI have them, Ride Quality is Great. The Mach only drops about 5/8 though. I think 1 inch is for the GTs
Hi Dan. My 2022 Steeda Mach 1 part sheet is on the following thread. This can give you an idea of how you want to build the suspension. Have fun.Which application/springs would you recommend to achieve a 3/4 to 1 inch lower stance for a Mach 1,
The warranty is only effected if it is determined the aftermarket part caused or contributed to a failure/repair. In that event only those parts in question wouldn't be covered.After I mount my new wheels, this is my next mod to do. For Those who have them on, did you install it yourself? Does this mod affect the warranty?
You answered my next question. To save on labor cost, I will opt to add the plates during the install. Since alignment will be needed, I will also add the alignment sleeves in the back. Cheers!The warranty is only effected if it is determined the aftermarket part caused or contributed to a failure/repair. In that event only those parts in question wouldn't be covered.
Make sure you get an alignment afterward. And definitely get camber plates installed with the springs.
