- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
Professional Motorsports Grade Camber Plates have been engineered & developed by Team MMR to allow for a wide range or camber adjustment to allow for maximum tire contact under hard cornering. By adding negative camber your car will push less through the corners (understeer), improve racetrack tire wear and decrease lap times. These plates will also correct excessive negative camber caused by lowering springs.
MMR Camber Plates Feature Billet Alloy Construction along with Stainless Steel glide Plates, Both parts are corrosion resistant and are designed for daily use all the way up to Professional competition. Our plates will grow with you as your skills improve providing adjustability and options to work with our coil over system as you upgrade.
MMR Camber plates feature optimized Caster built in, no adjustment needed making for a stronger camber plate and greatly decreased installation time.
Features:
Fully Rebuildable
Laser Marked for orientation and adjustment
Perfect for Lowered Vehicles
Decreases uneven tire wear
Largest adjustment Range on the market
Largest Available Motorsports Grade Teflon Lined Bearings
Stainless Steel Glide plates
Precisely CNC Machined
Dramatically Reduced Understeer
Manufactured by MMR in the USA
Tested by Team MMR
Compatible with aftermarket Coil over systems & aftermarket lowering springs
Fits 2015-2021 Mustang:
Ecoboost
V-6
GT
GT350/R
GT500
Purchase now! : https://www.modularmotorsportsracin...n_page=product_info&cPath=87&products_id=1424
Features:
Fully Rebuildable
Tested by Team MMR
Ecoboost
V-6
GT
GT350/R
GT500
