I went to the drag strip yesterday and this was my best time
Dinokill3.7
2017 Mustang Gt PP
6 speed 2017 GT PP
20 inch Velgen Classic 5 wheels
295x35x20 Kumho tires
BMR lowering springs
H pipe
Bassani axle back
Lund e85r tune
For context. The best I could do on the stock tune with 93 gas was this
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
If you aired down the rears a bit you probably would've dipped into the 12.4 range.
Torched10
Atlanta
Bob
1sr rt was very good.the 2nd not so good.may have cost you 0.4 sec.did you warm tires up.when I dragged my old 65 gto stock tri power car. an old timer gave me a tip on et times.when the light hits the last yellow say cheese to yourself and just go.id usually run .550to .6 ET on 4speed. in those days low,14s were great stock times
LSchicago
Illinois
Lloyd
1sr rt was veryy good.the 2nd n it so good.may have cist you 0.4 sec.did you warm tires up.when I dragged my old 65 gto and old timer gave me a tip on st.when the light hits the last yellow say cheese to yourself and just go.id usually run .550to 6 on 4 a.in tjospeed in this fays lowv14s were great stock.
My head hurts after attempting to read that.
OGFSU
West Covina CA
Nick
2016 Mustang GT Premium 6r80 IG: @ogfsu.s550
Wish we had a 1/4 track near me in SoCal (only have a 1/8th track near me) 🙁. Like LSchicago said, air down a bit and work on your launch. 2017 GT PP is a Mt-82 3.73 gears I believe. You should be able to get a better 60' with some practice:thumbsup:
Torched10
Atlanta
Bob
Sorry about that.heres readable note
1sr rt was very good.the 2nd not so good.may have cost you 0.4 sec.did you warm tires up.when I dragged my old 65 gto stock tri power car. an old timer gave me a tip on et times.when the light hits the last yellow say cheese to yourself and just go.id usually run .550to .6 ET on 4speed. in those days low,14s were great stock times.
This damn droid keeps making up words.ill have to use PC now.
wazslow
PA
2016 Mustang GT/CS
You do realize the r/t has nothing to do with the e.t. You can sit there for 10 seconds after the light turns green and still run a 10 second e.t.
Torched10
Atlanta
Bob
I realize that.but then you'll lose by 10 seconds.if your off .4 secs later than your rival,you'll pay for it at the end,
NASteve
Conroe, Tx
2022 Mustang GT
He isn't worried about winning or losing at this point, just the e.t..
OP if you had a more drag friendly wheel and tire combo then you'll be faster, but 20" wheels are not helping. You can try lowering the air press but I doubt it will help, maybe a few hundredths.
Prymetime1
Dion
2021 Mustang GT/CS,
6 speed 2017 GT PP
H pipe
Bassani axle back
Lund e85r tune
Thats a nice time slip for a mt from what i am reading. What rpm did u leave at? Traction control on? Curious to learn how to get our of the hole better as that should drop the et a bit....and hopefully break into 12s. 1st time out with my car n got to 13.0. So hopefully not to far out.
LSchicago
Illinois
Lloyd
Try traction control off, lower rear pressure (I only tried 22 on my 19 A10, dropped a tenth) and play with launch RPM. You should get 12's next time out.
Mn129
Plainfield, il
Mark
2019 gt350. 88 foxbody coupe
Reaction time doesn't have anything to do with you et
you can sit there for 10 seconds after green light. Time doesn't start until you roll through the beams😀
Torched10
Atlanta
Bob
True but you'll lose the race
