Alignment question for new rims and tires
AgSurfer
Ohio
2020 Shelby GT350R / 2021 Shelby GT500
I am having these SVE 350R 19x10 front and 19x11 rear rims installed on my 2018 Roush Phase II SC GT later this week. 285 Pilot Sport 4s on the front and 305 Nitto NT05Rs on the rear (I am using my existing Nitto NT05Rs and will be switching to a stickier tire after I burn these out later this year or next year - depending on driving habits). The car is lowered with Eibach Sportline springs, which I believe are approx. 1.5" front and 1.3" rear lower than stock. Based on collective research and feedback from other members running same / similar setup on their lowered cars, they did not have any clearance or rubbing issues. However, should I request any special alignment settings when having these installed? The 2018 GT does not see the race track (at least not yet and no plans to do so this year). It is primarily hard / spirted driving and will also see the strip later this year.
https://lmr.com/item/WK-177912A/mustang-sve-r350-wheel-kit-black-19x10-11-15-17
Thanks for the input.
NightmareMoon
2016 Mustang GT PP
About 0.1-0.15 toe in per side in the rear helps with straight line stability. Zero toe front is fine.
Don't go below about 1 degree of camber in the rear.
Less static camber isn't always better for grip, because the car squats under acceleration which dynamically changes the camber.
AgSurfer
AgSurfer
Ohio
Thank you. Very helpful. I will pass this along to the tech tomorrow morning.
shogun32
Northern VA
you have roll-center correcting front arms and bump steer kit? And camber plates?
AgSurfer
AgSurfer
Ohio
shogun32
Northern VA
if handling is a big factor, it's a good idea to add those parts. Rear camber the stock adjustment is perhaps sufficient. What were you planning to use for the front to get at least 1.3 if not closer to 1.7?
AgSurfer
AgSurfer
Ohio
Wouldn't the Maximum Motorsports adjustable caster / camber plates help achieve the desired alignment settings on the fronts?
shogun32
Northern VA
yes. you didn't mention that you had those. (or I'm blind)
AgSurfer
AgSurfer
Ohio
My bad; the specs are in my signature
So you're suggesting I set front camber to say 1.3-1.7?
And based on Nightmare Moon's recommendation, I should also set the following alignment:
Front: No change to toe
Rear: About 0.1-0.15 toe in per side in the rear helps with straight line stability. Don't go below about 1 degree of camber in the rear; or stock camber adjustment is sufficient
thanks.
shogun32
Northern VA
I have signature display turned off...
you want ~0.3 more camber up front than rear. If you settle on 1.0 out back, 1.3-1.5 up front.
1.3 out back -> 1.6+ up front.
zero toe or 0.1 total (L+R)
there should be enough room to get 1.0-1.3 at the rear with the stock adjusters.
NightmareMoon
2016 Mustang GT PP
Stock rear camber spec is -1.5 I'd start there unless you have a good reason to change it. Ideally slightly more front camber than rear, is ideal, sure, but if you don't have the adjustable camber plates I wouldn't worry about it.
AgSurfer
AgSurfer
Ohio
sorry - is this positive or negative camber on the front and rears you are referencing? I would think negative for improved cornering / handling - correct? Thanks.
shogun32
Northern VA
only pick-em-up-trucks run positive camber. Yes, always negative.
AgSurfer
AgSurfer
Ohio
I thought that was the case. I very much appreciate your and Nightmare's moons feedback on the alignment settings for this car.
Grintch
Hunstville
2015 GT PP
Why? For the drag strip?
I would want more (negative) camber for the street (especially if I already paid for camber plates). And a lot more for the road course/autocross course.
The Track Pack recommendation (which doesn't include front camber plates/adjustment) is
-1.6 F/-2 R IIRC.
